I would like to ask if it is possible to automatically import images through the generator and then automatically decal on the floor or wall?
I almost only found a part of the imported image.
Does anyone have a solution? Thank you very much.
As I stated on your previous topic on this subject, which has since been edited to just ādeleteā:
Likely, yes. Have a stab at it and let us know where you get. There are several examples in the forum you can use as a guide to get started.
@jacob.small I might be a hard ass about it, but I would recommend that we either answer the OPās question, flag it as inappropriate or simply refrain from answering.
Now, I would second your opinion about the fact that this was already answered before. Hereās a link to one such thread: Is it possible? This explains how to import images into Revit, and place them in drafting views if I am not mistaken.
@jacob.small I guess I am saying that if you say āthis was already answeredā, at least post a link to it.
The second part of the question, which asks about using an image as a ādecalā on a wall/floor is a little trickier. Technically OP is asking if its possible to import and image, and use it as a material on a wall/floor. From top of my head, that should be possible, but you would have to create a material, and assign it to the appropriate face. These methods are available in the API so it should be possible. I wonāt recommend that route, because I donāt know enough about what the OP intends to do with such workflow.
That second workflow would require some custom programming. You can get an idea how to create a material from here: https://forums.autodesk.com/t5/revit-api-forum/create-new-material-and-add-new-physical-and-thermal-assets-with/td-p/7308186
I think that the easiest way to assign a material to Wallās face might be the Paint method: http://www.revitapidocs.com/2018.1/f59f8872-e8d7-5d00-0e8c-44a36a843861.htm
Again, the above is quite involved, and no guarantee that the result will be what OP wants. @ssean7240
