Import a whole Excel workbook
All the excel import nodes seem to require sheet names.
Is it possible to just import the entire workbook?
I’d like all the tabs, not just one.
What have you tried so far? I’d take a look at the python the node uses and see if you find any options there. You can always look up the Excel API and see if there’s a way to either return all workbook data or to parse the existing worksheets one by one. There may even be a node already that can tell you all the worksheets in a file.
EDIT: A quick search shows that Sparrow and Data-Shapes both have nodes for getting worksheet names from a given file.
I was working on something like this today.
It is possible in the Excel Api.
In this case I need all the data of all the worksheets.
I need all the rows from the first, after that I need the second row to the last row.
Over here a C# example:
// Lees het Excel-bestand
                    var excelApp = new Application();
                    // Open het Excel-bestand
                    Workbook workbook = excelApp.Workbooks.Open(first_excel);
                    // Het eerste werkblad gebruiken
                    Worksheet firstSheet = workbook.Worksheets[1];
                    // StringBuilder voor elke rij
                    StringBuilder resultBuilder = new StringBuilder();
                    string firstName = firstSheet.Name;
                    int startIndex = 1;
                    foreach (Worksheet ws in workbook.Sheets)
                        string wsName = ws.Name.ToLower();
                       // Krijg het gebruikt bereik in het werkblad
                            var usedRange = ws.UsedRange;
                            if (ws.Name != firstName)
                                startIndex = 2;
                          for (int i = startIndex; i <= usedRange.Rows.Count; i++)
                              string result = ConvertWorksheetToString(ws, i);
                              resultBuilder.Append(result);
                          ReleaseComObject(ws);
Release object:
static void ReleaseComObject(object obj)
            try
                Marshal.ReleaseComObject(obj);
            catch (Exception ex)
                Console.WriteLine($"Fout bij het vrijgeven van COM-object: {ex.Message}");
            finally
                obj = null;
ConvertWorkSheetToString:
static string ConvertWorksheetToString(Worksheet worksheet, int rowIndex)
            // StringBuilder wordt gebruikt om efficiënt strings op te bouwen
            var resultBuilder = new System.Text.StringBuilder();
            var usedRange = worksheet.UsedRange;
            // Voeg kolomkoppen toe aan de resultaten
            for (int col = 1; col <= usedRange.Columns.Count; col++)
                string cleanedValue = null;
                try
                    string cellValue = usedRange.Cells[rowIndex, col].Value2.ToString();
                    // Controleer of de celwaarde null of leeg is, en trim eventuele voorloopse en volgroepruimte
                    cleanedValue = (!string.IsNullOrWhiteSpace(cellValue)) ? cellValue.ToString().Trim() : "-";
                catch
                    cleanedValue = "-";
                resultBuilder.Append(cleanedValue);
                resultBuilder.Append(";");
            resultBuilder.AppendLine();
            // Converteer de StringBuilder naar een string en retourneer deze
            return resultBuilder.ToString();
I’d recommend looking into the source code form the OpenXML nodes, as the worksheets can be exposed that way as well.
