In versions prior to 0.7, whenever you tried to read an excel file, there was an option to browse all the worksheets from inside the file and automatically select one, without having to specify its name. It seems that in the later versions this functionality has been hidden in the library. However it’s still active because if you upgrade a file from 0.63 to 0.7+ the nodes are still working:
<p class=“alignleft size-medium wp-image-9738”>Right now my workaround is to add the updated nodes into a custom node and re-use them that way. Is this advisable? Are there plans to bring this functionality back?</p>
