after install/update IFC Exporter addins, you should have this in the C:\ProgramData\Autodesk\ApplicationPlugins directory
Hey Cyril,
yes, sorry, I checked it today once again and realised that for our 2024 version it uses the 2023 bundle.
In the code the version ( variable {1} ) thus points to a directory of a version 2024, not 2023.
Replacing the code to
ifc_bundle_path = “{0}\Autodesk\ApplicationPlugins\IFC 2023.bundle\Contents\2023”
solved the first issue. Another error occours:
but hey, one step closer!
try to replace
#Define the of a 3d view to export
exportViewId = None
by
exportViewId = ElementId.InvalidElementId
I update my code here
you can simply adapt the 2nd python script with inputs (no need for a 3rd python script)
code Get IFC Configuration
import sys
import System
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.Attributes import *
from Autodesk.Revit.DB.IFC import *
app = uiapp.Application
sdkNumber = int(app.VersionNumber)
IFCExportConfiguration = None
IFCExportConfigurationsMap = None
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
pf_data_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.CommonApplicationData)
ifc_bundle_path = "{0}\\Autodesk\\ApplicationPlugins\\IFC {1}.bundle\\Contents\\{1}".format(pf_data_path, sdkNumber)
if System.IO.Directory.Exists(ifc_bundle_path):
# 1st try
sys.path.append(ifc_bundle_path)
clr.AddReference("IFCExporterUIOverride")
from BIM.IFC.Export.UI import IFCExportConfigurationsMap, IFCExportConfiguration, IFCCommandOverrideApplication
ifc_addin_path = "{}\\Autodesk\\Revit {}\\AddIns\IFCExporterUI".format(pf_path, sdkNumber)
if System.IO.Directory.Exists(ifc_addin_path):
# 2nd try
sys.path.append(ifc_addin_path)
clr.AddReference("Autodesk.IFC.Export.UI")
import json
ifc_dict_config = {}
if IFCExportConfigurationsMap is not None:
idfdocA = IFCCommandOverrideApplication.TheDocument
if idfdocA is None:
propinfo = clr.GetClrType(IFCCommandOverrideApplication).GetProperty('TheDocument')
propinfo.SetValue(None, doc)
configurationsMap = IFCExportConfigurationsMap()
configurationsMap.AddBuiltInConfigurations()
configurationsMap.AddSavedConfigurations()
for config in configurationsMap.Values:
print(config.GetType())
#dict_ifc_version_str = {"IFC_Version_str": config.IFCVersion.ToString() }
#dict_config = json.loads(config.SerializeConfigToJson())
# merge dictionaries
#merge_dict_3 = dict(dict_ifc_version_str,**dict_config)
ifc_dict_config[config.Name] = config
OUT = ifc_dict_config
code export ifc
import sys
import System
# Import RevitAPI
from Autodesk.Revit.Attributes import*
from Autodesk.Revit.DB.IFC import*
myIFCExportConfiguration = IN[0]
view3d = UnwrapElement(IN[1])
folder_ifc_path = IN[2]
out_ifc_name = IN[3]
options = IFCExportOptions()
exportViewId = view3d.Id if view3d is not None else ElementId.InvalidElementId
# Pass the setting of the myIFCExportConfiguration to the IFCExportOptions
myIFCExportConfiguration.UpdateOptions(options, exportViewId)
result = doc.Export(folder_ifc_path, out_ifc_name, options)
OUT = result
It works, thanks alot!
Hello.The method used my @c.poupin works for a single view export with specific IFC configuration but it does not work when I try it with a list in the views Port (I would like to batch export multiple views with a specific IFC export configurations and the Genius Loci node does not allow it). Would someone have an idea of how I could modify the second script (answer above) for working with multiple 3D view export?
The actual node give me the error "
Thank you
I am 99% sure that Genuis Loci’s node does allow for multiple views. As i am using it for multiple views.
Judging from the error i assume your input is incorrect, Can you show the export node and everything that is going into the node?
Thank you for answering. yes Loci node allows multiple view export but does not allow to get a specific revit IFC Export configurations. I finally succeeded modifying the code like this.
import sys
import System
# Import RevitAPI
# Données d'entrée
myIFCExportConfiguration = IN[0] # Configuration d'export IFC
views3d = [UnwrapElement(v) for v in IN[1]] # Liste des vues 3D à exporter
folder_ifc_path = IN[2] # Chemin du dossier où enregistrer les IFC
out_ifc_names = IN[3] # Liste des noms de fichiers IFC pour chaque vue 3D
# Vérification de la cohérence des listes
if len(views3d) != len(out_ifc_names):
raise ValueError("Le nombre de vues 3D et le nombre de noms de fichiers doivent être égaux.")
# Initialisation de la liste des résultats d'exportation
export_results = []
# Boucle sur chaque vue 3D pour effectuer l'exportation
for i, view3d in enumerate(views3d):
if view3d is not None:
out_ifc_name = "{}.ifc".format(out_ifc_names[i]) # Utilise le nom de fichier spécifique de la liste
# Récupère l'ID de la vue 3D à exporter
# Applique la configuration IFC spécifiée à l'option d'exportation
# Effectue l'exportation et stocke le résultat
export_results.append(result)
# Sortie des résultats d'exportation
OUT = export_results
Hi, I had a similar problem as @Chrissi with the first Python script.
I switched to CPython3, pasted the latest script, and it worked.
However, the second Python script is causing an issue. I’ve already switched to CPython3 and pasted the latest script, but it’s giving me an error (see screenshot).
MISOS_Export IFC with config_WIP.dyn (44.8 KB)
It turns out the issue was with the inputs. I was using a @Garbage_Collector dyn file, and it seems there might have been some incorrect labeling, which caused me to feed the script the wrong data. So yes, the problem was due to incorrect inputs.
With the help of ChatGPT, I was able to fix it and even improve the script for my needs. I needed it to handle two different IFC configurations: one for exporting the architectural model with rooms and another for the structural and interior elements without rooms.
Now, the script works great—I’ve set it up to use a list of views, file names, and IFC configurations, and everything is running smoothly.
I’m sharing the script here in case you’d like to take a look or give me some feedback.
MISOS_Export IFC with config_WIP.dyn (56.0 KB)
Thank you all again.
Hi I’m trying to get this to work usingan exported json setup file rather than accessing the IFC bundle. This is becasue the location of the bundle cannot be determined as it’s deployed in my company via a PDQ and I cannot confirm location on different setups.
Can someone point me in the right direction, this is what I have so far
Unfortunately, it does not seem possible to add ClassificationSettings easily.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.ExtensibleStorage import *
import System
from System import Guid, String, Int32 # for ExtensibleStorage
import traceback
lstOUT = []
docCheck = ... your own document
lst = [
[Int32,"ClassificationEditionDate_Day",0o1, SpecTypeId.Int.Integer],
[Int32,"ClassificationEditionDate_Month",0o1, SpecTypeId.Int.Integer],
[Int32,"ClassificationEditionDate_Year",2005, SpecTypeId.Int.Integer],
[String,"ClassificationFieldName","Assembly Code", SpecTypeId.String.Text],
[String,"ClassificationLocation","https://nlsfb.ketenstandaard.nl/", SpecTypeId.String.Text],
[String,"ClassificationName","NL/SfB (4 cijfers)", SpecTypeId.String.Text],
[String,"ClassificationSource","BIMloket", SpecTypeId.String.Text],
[String,"ClassificationEdition","_2005_", SpecTypeId.String.Text]
gui = Guid("9A5A28C2-DDAC-4828-8B8A-3EE97118017A")
TransactionManager.Instance.EnsureInTransaction(docCheck)
try:
lstFilter = []
lstFilter.append(ExtensibleStorageFilter(gui))
obFilter=LogicalAndFilter(lstFilter)
lstCollector = FilteredElementCollector(docCheck).OfClass(DataStorage).WherePasses(obFilter).ToElements()
if len(lstCollector) >= 1:
ob = lstCollector[0]
ent = ob.GetEntity(Schema.Lookup(gui))
for i in lst:
ent.Set[i[0]](i[1],i[2],i[3])
ob.SetEntity(ent)
lstOUT.append([lst,lstCollector,ob,ent,"Classification changed"])
ob = DataStorage.Create(docCheck)
sch = SchemaBuilder(gui)
# 2 Set the read/write access for the schema
sch.SetReadAccessLevel(AccessLevel.Public)
sch.SetWriteAccessLevel(AccessLevel.Public)
sch.SetSchemaName("IFCClassification")
# 3 Define one or more fields of data for the schema
for i in lst:
sch.AddSimpleField(i[1], i[0])
sch.Finish()
# 4 Create an entity based on the schema
sch = Schema.Lookup(gui) # seems to be neccesary
ent = Entity(gui)
# 5 Assign values to the fields for the entity
for i in lst:
fld = sch.GetField(i[1])
ent.Set[i[0]](fld,i[2],i[3])
# 6 Associate the entity with a Revit element
ob.SetEntity(ent)
lstOUT.append([ob,"Classification created"])
except:
lstOUT.append(["Classification name","is proberbly wrong",traceback.format_exc(),i,sch,fld,ent])
OUT = lstOUT
These settings are a part of the ExtensibleStorage in your project. Just try LookUp addin to check the GUID.
@nmcmahonTW94C this is the part of the code that does the job for us.
Be aware this needs to be an PythonNet3 node (or IronPython2.7 for old projects). CPython does not work.
@c.poupin perhaps you can see some more improvements.
No particular comments, it’s good to have thought to specify the type of parameter (template parameter) with the Set[T]() method (to avoid overload issue).
