Hi guys,
I am using the custom node “Export IFC” from GeniusLoci.
This Python script refers to AddOptions such as: options.AddOption(“ExportLinkedFiles”, “false”)
However, despite all the comments on these forums the options don’t seem to do anything here…
If i set the ExportLinkedFiles option to “true” it doesn’t export the linked file in my model.
None of the options seem to work, tested multiple.
Am i doing something wrong here? If so, what can i do to fix this problem?
The Python script:
#Proposed by Nicklas Verdier Østergaard, nvo@niras.dk
#https://github.com/pzurek/ifcexporter/blob/master/IFCExporterUI/Source/IFCExportConfiguration.cs
#Revised by Alban de Chasteigner
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
folder=UnwrapElement(IN[0])
name=UnwrapElement(IN[1])
view = UnwrapElement(IN[2])
fileversion = IN[3]
wallandcolumnsplitting = IN[4]
exportbasequantities = IN[5]
Projectorigin = IN[6]
#IFCVersion=UnwrapElement(IN[3])
result = []
for i,v in enumerate(view):
options=IFCExportOptions()
#if fileversion != None:
# options.FileVersion = fileversion
if fileversion == "IFC4":
options.FileVersion = IFCVersion.IFC4
if fileversion == "IFC2x2":
options.FileVersion = IFCVersion.IFC2x2
if fileversion == "IFC2x3":
options.FileVersion = IFCVersion.IFC2x3
options.FileVersion = IFCVersion.IFC2x3CV2
if fileversion == "IFCBCA":
options.FileVersion = IFCVersion.IFCBCA
if fileversion == "IFCCOBIE":
options.FileVersion = IFCVersion.IFCCOBIE
if fileversion == "":
options.FileVersion = IFCVersion.Default
options.WallAndColumnSplitting = wallandcolumnsplitting
options.ExportBaseQuantities = exportbasequantities
options.FilterViewId = v.Id
options.AddOption("ExportInternalRevitPropertySets","true");
options.AddOption("ExportIFCCommonPropertySets","true");
options.AddOption("ExportAnnotations ","true");
options.AddOption("SpaceBoundaries ", "0");
options.AddOption("ExportRoomsInView", "false");
options.AddOption("Use2DRoomBoundaryForVolume ", "false");
options.AddOption("UseFamilyAndTypeNameForReference ", "true");
options.AddOption("Export2DElements", "false");
options.AddOption("ExportPartsAsBuildingElements", "false");
options.AddOption("ExportBoundingBox", "false");
options.AddOption("ExportSolidModelRep", "true");
options.AddOption("ExportSchedulesAsPsets", "false");
options.AddOption("ExportSpecificSchedules", "false");
#Doesn't work. It would be necessary to use OpenInBackground.
options.AddOption("ExportLinkedFiles", "false");
options.AddOption("IncludeSiteElevation","true");
options.AddOption("StoreIFCGUID", "true");
options.AddOption("VisibleElementsOfCurrentView", "true");
options.AddOption("UseActiveViewGeometry", "true");
options.AddOption("TessellationLevelOfDetail", "1");
options.AddOption("ExportUserDefinedPsets","false");
options.AddOption("SitePlacement", IN[6]);
# options.AddOption("ExportUserDefinedPsetsFileName","the filepath")
#IFCVersion Version = (IFCVersion) Enum.Parse( typeof(IFCVersion), UnwrapElement(IN[3]), true );
#x.FileVersion = IFCVersion.IFC2x3CV2
c=doc.Export(folder, name[i], options)
result.append(c)
# End Transaction
OUT="Default settings used"
OUT='Success'
Thanks in advance
