We have been getting more reports of an issue affecting Dynamo / Autodesk analytics.
There are a few analytics launch issues floating around the forum so please check the stack trace here to ensure you’ve seen this particular stack trace before trying this workaround.
We believe the issue is with an update to ADP - Autodesk’s analytics component that Dynamo uses. This can be installed globally automatically or by other applications - a particular version 4.4.0 causes issues with DynamoRevit 2021.
Coming soon there should be an automated delivery of a new version that will resolve this issue - but to get Dynamo working again NOW you can try this workaround.
Simpler Experimental Alternative
These are unconfirmed simpler solutions to try first.
- Close all autodesk products/Dynamo.
- Try opening a newer ADSK product and disable Analytics from the UI in that product.
- Open Dynamo in a newer ADSK product like, Revit 2022 and disable Analytics there.
- Try rebooting Revit 2021.
A warning it is a bit painful.
Navigate to %appData%\Roaming\Autodesk\ADPSDK\bin and ensure that the binaries in this folder are version 4.4.0. To check the Binaries version:
a) Right-click on the binaries here, such as ADPSDKCore.dll, select
Properties, navigate to theDetailstab, and check out theFile Versionproperty.
Backup the files in this folder to a safe location.
You may need admin rights for the following steps.
Unzip the attached 7zip archive and copy the files from the unzipped bin folder to the existing bin folder.
You will likely get an error that access is denied etc.
Open the Task Manager and close ADSSO, Autodesk Identity etc, anything named Autodesk and all ADSK applications.
Hit retry on the copy dialog.
You may need to do this multiple times.
You may need to open services from the start menu and disable any service that starts with Autodesk.
It may be simpler to create a new user account on your machine with admin privileges and use it to copy the files to your normal user account’s adp folder.
- It MAY be possible as a temporary work around to simply delete the entire bin folder - but this depends on what other versions of ADP are installed on your machine and it will only work temporarily.
adp_bin 4.4.1.7z (4.1 MB)
If possible - use newer Dynamo versions temporarily, if not you can try this workaround or wait until the automatic update resolves this issue.
