I wrote code block of " if…elseif…else" for testing a list and output different string, but the output is always the first item, please help?
Hi @yatcheung, welcome!
Since you are using key:value
pairs to check if a string contains a certain sub-string and return a result then a dictionary is probably the way to go
def check_pipe(str, dict)
return = [Imperative]
for (k in dict.Keys)
if (String.Contains(str, k))
return = dict[k];
return = null;
Recived with thanks, I am working with your suggestion and the problem solved.
Your are very helpful for this issue, thanks a lot!
