"if" node with list is strange
Hello
When I branch a list with different number of elements with “if” node, the number of elements in the list obtained as result changes.
It seems to behave like Lacing’s minimum.
How can I get the exact list I entered from result?
In the example below, when true, expect a list of 1 to 10.
In addition, I got the same result when I used the ternary operator in Code Block.
Thank you
if_node_with_list
I think this has been noted a few times, you can do a search. Try Scope If from clockwork package.
Two lines of design script also works:
indx = test?0:1;
lst = [trueList,falseList][indx];
Thank you all.
From the reply, I understood that it cannot be achieved by using “if”.
I will use the method you taught me.
I searched the forums and found a same question.
I will also post the link.
Thank you very much.
