IF node broken?
See the picture below;
I’ve used the IF node and fed it 2 lists and a boolean.
The Boolean returns true, so the first list should be returned.
Before the list goes into the IF-node it has 10 items, after it comes out it only has 9 items. Where did the last item go?
It’s caused by the lacing. The if node has shortes lacing as default, and it can’t be changed. Try the scopif or a simple python script.
if IN[0]:
	OUT = IN[1]
	OUT = IN[2]
The behavior was changed in this PR:
Additional notes:
  • With a formula node you can change lacing.
  • Design Script if behaves the same way as the if node.
Thanks for your reply Einar,
I’ve tried this solution and i’m even more surprised now… this time it misses 2 items in my List.
Hello, could you please tell what is tested with String.Contains?
@M.Melching right click the Formula node and choose longes lacing.
In principle, it works:
This was the right answer. Well, it was the lacing. It chose the shortest list as lacing. Thanks for solving this
