Why IF node is not working
Why the IF node is not working?
With my test the result should be 16, not 12
If node doesn’t have lacing in any of the old builds, and as a result shortest lacing is always used. Upgrade to something new and more current and you should get the behavior you want.
Alternatively you can use this is a code block:
indx = test? 0:1;
result = [trueList, falseList][indx];
Ok, merci
