Hello, I am trying to mark the points normal to the 3D polyline using vector. but as seen in the image, for a small patch the vector changes to opposite direction. any leads or solution on how I can identify and reverse (vector.reverse node does help) the direction of those vectors and create the updated list.
Hi @SkUbaid you could try “normal at parameter” or the new one with side
…if the old one i like to calculate the vector cross, between normal and tangent
Hi @SkUbaid
(Short answer) To solve this problem, use
Use this node from the Brimohareb_XXXX package to get the vector.
(Long answer) read these post ![]()
( Rotation Minimizing frames)
Thank you @sovitek, it works perfect. Have been scratching my head all day for this
since I am using 2023 version the first option works for me.
@RMohareb, I will definitely try with the node from the package and will get back to you if I face any issues or challenges. the node does seems promising.
And for the document file and link I have my weekend sorted with that. ![]()
