These are my code
# Import Common Language Runtime
# Import Revit Services
from System.Collections.Generic import IList
clr.AddReference('RevitAPI')
import System
#get the document
#Function
def line(number1, number2, number3, number4, number5, number6, number7, number9, number10):
XR1 = clr.StrongBoxStructure.RebarFreeFormValidationResult
XR2 = clr.StrongBoxStructure.RebarFreeFormValidationResult
x1 = number1
y1 = number2
z1 = number3
x2 = number4
y2 = number5
z2 = number6
nx1 = number1 + number7
count = 0
#While loop to auto create point that move 300 mm in y direction everytime loop goes.
while (count < 2):
pt1 = XYZ(x1, y1, z1)
pt2 = XYZ(x2, y2, z2)
pt3 = XYZ(nx1, y1, z1)
pt4 = XYZ(nx1, y2, z2)
#Create line using pt1, pt2, pt3 and pt4
line1 = DB.Line.CreateBound(pt1, pt2)
line2 = DB.Line.CreateBound(pt3, pt4)
#Start Transaction
rebar_list = []
#Create Rebar from Line that use pt1 and pt2 as start and finish point
rebar1 = Structure.Rebar.CreateFreeForm.Overloads[Document, RebarBarType, Element, IList[IList[Curve]], RebarFreeFormValidationResult](doc, number9, number10, line1, XR1)
#Create Rebar from Line that use pt3 and pt4 as start and finish point
rebar2 = Structure.Rebar.CreateFreeForm.Overloads[Document, RebarBarType, Element, IList[IList[Curve]], RebarFreeFormValidationResult](doc, number9, number10, line1, XR2)
rebar_list.append(rebar1.ToDSType(False))
rebar_list.append(rebar2.ToDSType(False))
#End Transaction
#y-axis coordination move
y1 = y1 + number7
y2 = y2 + number7
#increase loop count
count = count + 1
#Scripts Inputs
num1 = IN[0]
num2 = IN[1]
num3 = IN[2]
num4 = IN[3]
num5 = IN[4]
num6 = IN[5]
num7 = IN[6]
style = UnwrapElement(IN[8])
type = UnwrapElement(IN[9])
model = UnwrapElement(IN[10])
#Call Function
result = line(num1, num2, num3, num4, num5, num6, num7, type, model)
OUT = rebar_list
When I run these code its shown AttributeError: ‘module’ object has no attribute ‘StrongBoxStructure’ what system did I forget to import? or Is there a mistake among those line of code of my?
