I try to create rebar base on these following code
# Import Common Language Runtime
# Import Revit Services
clr.AddReference('RevitAPI')
import System
#get the document
#Function
def line(number1, number2, number3, number4, number5, number6, number7, number8, number9,
number10):
x1 = number1
y1 = number2
z1 = number3
x2 = number4
y2 = number5
z2 = number6
nx1 = number1 + number7
count = 0
while (count < 2):
pt1 = XYZ(x1, y1, z1)
pt2 = XYZ(x2, y2, z2)
pt3 = XYZ(nx1, y1, z1)
pt4 = XYZ(nx1, y2, z2)
line1 = DB.Line.CreateBound(pt1, pt2)
line2 = DB.Line.CreateBound(pt3, pt4)
rebar1 = Rebar.CreateFromCurves(doc, number8, number9, startHook, endHook,
number10, norm, line1, SHorient, EHorient, True, False)
rebar2 = Rebar.CreateFromCurves(doc, number8, number9, startHook, endHook,
number10, norm, line2, SHorient, EHorient, True, False)
y1 = y1 + number7
y2 = y2 + number7
count = count + 1
num1 = IN[0]
num2 = IN[1]
num3 = IN[2]
num4 = IN[3]
num5 = IN[4]
num6 = IN[5]
num7 = IN[6]
style = UnwrapElement(IN[8])
type = UnwrapElement(IN[9])
model = UnwrapElement(IN[10])
rebar = []
result = line(num1, num2, num3, num4, num5, num6, num7, style, type, model)
OUT = rebar1, rebar2
But its shown NameError: global name ‘Rebar’ is not defined. My target is to repeating create rebar as node move. I mean for example loop 1 start point (0,0,0) end point (0,0,10000) then loop 2 start point (0,300,0) end point (0,300,10000) which I already succeed in make looping node creation with these code but creating line and use that line to create rebar using Rebar.By.Curve is still unable to run. So how do I solve NameError: global name ‘Rebar’ is not defined and how can I reduce these
public static Rebar CreateFromCurves(
Document doc,
RebarStyle style,
RebarBarType barType,
RebarHookType startHook,
RebarHookType endHook,
Element host,
XYZ norm,
IList<Curve> curves,
RebarHookOrientation startHookOrient,
RebarHookOrientation endHookOrient,
bool useExistingShapeIfPossible,
bool createNewShape
Largely requirement to more simple like this
Document doc,
RebarStyle style,
Element host,
