How to write Text to multiple PaperSpaces?
Good morning to all!!!
I am making a script in which I write a text on all the presentations in paper space. I have made an attempt but it only writes the text in the paper space that I have activated.
CREAR TEXTO EN ESPACIO PAPEL.dyn (48.1 KB)
Hi @CARodriguezA ,
The Document.PaperSpace node only returns one PaperSpace (Block), not all of them.
Try something like this to get all the PaperSpace Blocks.
Good morning Dan!!
I’ll try it, but I think I explained myself wrong, the scrypt works, but it inserts the text in the paper space that I have activated (only in one). example if I want to put in paper space 1 of 3, 2 of 3, 3 of 3, one for each plane writes it to me the three in the same presentation
For me it placed 1 text per PaperSpace using the top part from my script as the “Block” input in the Text.Create node, so please try that.
If that still doesnt work please supply a screenshot of what you have then :slight_smile:
Hi @CARodriguezA.
The method suggested by @Daan should work. Here is an example.
text
