Hi everybody…
How to work whith phase filters?
Can i create/delete/modify phase filters?
Can i get all the phase filters in the model?
Thanks in advance!!
Hi everybody…
Thanks in advance!!
Please try to use the search field before asking and consider sending a screenshot of your graph clearly showing the specific issues you encounter while building your workflow.
https://forum.dynamobim.com/search?q=phase%20filter
Sorry…
I’ve searched how to create, delete or modify phase filters and I don’t
found anything.
“Create” and other methods are exposed in the API, so something should be possible:
http://www.revitapidocs.com/2017.1/5b5cf504-33da-32ae-4371-37016f3c1a19.htm
"Delete" will probably be possible with Element.Delete from Archi-lab_Grimshaw.
Archi-lab could have had a node called View.CreatePhaseFilter in the past, see here:
