I would like to apply each item of the first list to each item of the second list using python or vice versa. I have only been able to add each item of first list to each item of second list.
There must be a simple way to do this. Please advise.
I forgot to mention that i would like it to read as GF_Level 1, GF_Level 2, GF_Level 3 etc. and the same for the next item in floor list to do the same.
It is easy if you don’t think about lacing in python node (it does’nt exist
Simply do a loop for all levels and then a nested loop for all floors
You should read like for each level, do this for each floor…
for l in mylist:
for f in floor:
output.append( l f )
Thanks a lot Fabio, It worked.
you’re welcome.
Switching order of loops will act like the transpose block
switching f and l, will provide you inverted concats
Actually , i was struggling with understanding the manner of reading the list. I tried several times to understand what it was doing - a loop within a loop. For each item in first list, do the “For each item in second list” . Is that the right way of reading it, cos i cant get my head around it.
Sorry still a newbie.
Try think like an excel spreadsheet:
for all sheets…
for all lines…
for all columns…
you are reading line by line, doing something each column (cell)
Ah, I c, so when i repeat the for loop inside a for loop it applies to the first column of the cell. Out of curiosity, is it possible to do this in excel (it would be so much easier:) ) , i tried, but it doesnt loop one item of one cell to many cells.
