Guys, I’m trying to make some code (C#) and integrate it with the Bim dynamo…
Is it possible to make a web request in C# and retrieve it to dynamo bim?
I kind of made an API in another language and I would like to consume it with C# by integrating it with Dynamo Bim
You should be able to add the DLL as a library as per the instructions halfway down this page where it says Opening the project's dll file.
But that said you likely want to generate the class in a way which makes things more Dynamo friendly. This write up can help with that: Dynamo Unchained 1: Learn how to develop Zero Touch Nodes in C#
For web requests, you can find several methods in the HttpClient .Net Class
HttpClient
Hi @Lincoln
Could this be of any use to u, have a look if it helps.
regards,
BM
Hi @Lincoln ,
I wrote some articles recently, it’s write in Python (IronPython and a little PythonNet) but the examples are easily portable to C#
maybe this will help you
you can use translate widget
