I have alignment converted to polycurve extract to curves start , mid and end points and converted to cogo points but number sequence are not comming correctly.
i need to sort numbers based on curve start , mid and end curve ( 2,3 and 4)
hi, here is an example of points not all being on a line then classify in ascending order with the parameter
I don’t have civil 3d
Sincerely
christian.stan
Maybe this could help?
The intersected lines where created in the order as you can see in the picture (the orange circles)
By sorting them based on the stationing I could created the cogopoints and correct order (the green circles)
Thanks , its working .
Glad that it worked out fine!
