I wrote a script to read an Excel spreadsheet, and it runs well in the Dynamo editor. However, when I run it in Dynamo Player, it doesn’t display inputs for the user to select the file path and sheet name. Is there a way to make these inputs visible in Dynamo Player?
Thanks. I’ve checked “Is Input” for those 2 nodes, but it doesn’t work.
If you are on Civil3D 2024, try adding “Watch” node to graph and set it as “Is Output”.
Look also at this link
Yes, the watch node works like magic!
