I’m trying to change the pipe label leader visibility setting by a routine in pyhton, but it’s not working.
I want to switch from “From Label Style” to “Always Hide”
This is my code:
import sys #sys is a fundamental Python library - here, we're using it to load in the standard IronPython libraries
import clr #This is .NET's Common Language Runtime. It's an execution environment that is able to execute code from several different languages.
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('ProtoGeometry') #A Dynamo library for its proxy geometry
#classes. You'll only need this if you're interacting with geometry
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('Civil3DNodes')
clr.AddReference('AutoCADNodes')
import Autodesk #Loads the Autodesk namespace
AAR = Autodesk.AutoCAD.Runtime
AAA = Autodesk.AutoCAD.ApplicationServices #Setting a handle to the currently-open instance of the AutoCAD application
AAD = Autodesk.AutoCAD.DatabaseServices
AAE = Autodesk.AutoCAD.EditorInput
AAG = Autodesk.AutoCAD.Geometry
AADy = Autodesk.AutoCAD.DynamoNodes
AUX = Autodesk.Aec.DatabaseServices
OP = AAD.OpenMode
TS = AAD.Transaction
ACA = Autodesk.Civil.ApplicationServices #Setting a handle to the currently-open instance of the Civil3D application
ACD = Autodesk.Civil.DatabaseServices
ACDy = Autodesk.Civil.DynamoNodes
AD = ACA.CivilApplication.ActiveDocument #Finally, setting up handles to the active Civil3D document
AC = Autodesk.Civil
adoc = AAA.Application.DocumentManager.MdiActiveDocument
editor = adoc.Editor
#Inputs:
#IN[0][0] -> Pipe Label
with adoc.LockDocument():
with adoc.Database as db:
# E vem ai:
Object = TS.GetObject(t,IN[0][0].Id,OP.ForWrite)
Object.UpgradeOpen()
Object.LeaderVisibility.AlwaysHide
t.Commit()
OUT = Object
