Changing the visibility of layers, in a viewport (VP Freeze)
Hi everyone,
For our project, we need to filter our AutoCAD viewports in terms of the appropriate layer visibility (the “VP Freeze” parameter):
I found some Python code by @zachri.jensen to change the layer visibility/ freeze parameter for the layers in the modelspace. I was wondering if a similar method could be used to change the visibility parameter per viewport:
The Code/ Topic of mzjensen
Freeze layer by name - dynamo Civil 3D - #10 by mzjensen
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
def set_layer_on_off(layers,bool):
	if layers is None:
		return None
	if bool is None:
		return None
	errorReport = None
	name=[]
	global adoc
	with adoc.LockDocument():
		with adoc.Database as db:
				for layer in layers:
					lt=t.GetObject(db.LayerTableId,OpenMode.ForWrite)
					try:
						if lt.Has(layer):
							i = t.GetObject(lt[layer], OpenMode.ForWrite)
							i.IsOff=bool
							name.append(i.Name)
					# Error handling
					except:
						import traceback
				t.Commit()
	if errorReport == None:
		return name
		return errorReport
OUT = set_layer_on_off(IN[0],IN[1])
Autodesk page about the Viewport Class
PS: This Dynamo script for me is a work in progress so I’ll post updates in this topic when I find some more information/ (parts of the) solution periodically. :slight_smile:
You can’t access the VP Frozen property directly from the layer. There is a function GetViewportOverrides([viewport id]) that returns the color, linetype and so on, and the layer itself has properties that tell if a layer has overrides.
But if you want to see or set the frozen layers you need to access them via the viewport object. More info about that:
Just found this link, which links to another page about ViewPorts which shows a C# approach to thawing or freezing layers in a viewport.
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseServices_Viewport_ThawLayersInViewport_IEnumerator
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseServices_Viewport_FreezeLayersInViewport_IEnumerator
PS: This is a different page from the ViewPort Class page from my original post.
Also, this code might be of interest (from Read properties of a viewport):
Code
private void VPLOOP()
        Document doc = Core.Application.DocumentManager.MdiActiveDocument;
        Autodesk.AutoCAD.GraphicsSystem.Manager gsm = Core.Application.DocumentManager.MdiActiveDocument.GraphicsManager;
        Database db = doc.Database;
        Editor ed = doc.Editor;
        LayoutManager lm = LayoutManager.Current;
        int x = 0;
        List<string> layers = new List<string>();
        foreach (AcadLayer layer in ThisDrawing.Layers) {
                layers.Add(layer.Name);
        using (tr == db.TransactionManager.StartTransaction()) {
                ObjectId idLay = default(ObjectId);
                ObjectId idLayTblRcd = default(ObjectId);
                LayerTableRecord lt = default(LayerTableRecord);
                Point3d llc = default(Point3d);
                Point3d urc = default(Point3d);
                // Save the name of the current layout
                currentLayout = lm.CurrentLayout;
                ObjectId loid = LayoutManager.Current.GetLayoutId(lm.CurrentLayout);
                Layout lo = tr.GetObject(loid, OpenMode.ForRead);
                //For Each de As DBDictionaryEntry In layoutDict
                lm.CurrentLayout = currentLayout;
                string layoutName = lo.LayoutName;
                if (x == 0 && layoutName != "Model") {
                        //Loop thru layout viewports
                        //Note, the first vp is the layout vp itself
                        ObjectIdCollection vpIdCol = lo.GetViewports();
                        //Looping through the collection of viewports
                        foreach (ObjectId vpId in vpIdCol) {
                                Viewport vp = vpId.GetObject(OpenMode.ForRead);
                                //Make sure we're not checking the overall layout viewport
                                if (vp.Number > 1) {
                                        LayerTable ltt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead, false);
                                        foreach (string lname in layers) {
                                                idLay = ltt(lname);
                                                lt = tr.GetObject(idLay, OpenMode.ForRead);
                                                if (ltt.Has(lname)) {
                                                        idLayTblRcd = ltt.Item(lname);
                                                } else {
                                                        ed.WriteMessage("Layer: \"" + lname + "\" not available");
                                                        VPortX = VPortX + 1;
                                                        break;
                                                if (vpId.IsNull()) {
                                                        ed.WriteMessage("No Viewport current.");
                                                        //I would rather just 'Exit Sub' but the transaction needs to be disposed, so we go down to that point in the code.
                                                        goto endusing;
                                                if (!vp.IsLayerFrozenInViewport(idLayTblRcd)) {
                                                        LayerTableRecord newLayer = (DatabaseServices.LayerTableRecord)db.TransactionManager.GetObject(idLayTblRcd, DatabaseServices.OpenMode.ForRead);
                                                        if (!newLayer.IsFrozen && !newLayer.IsOff) {
        int vpn = vp.Number - 1;
        if (!ValidLayers.Contains(newLayer.Name + "," + vpn.ToString())) {
        ValidLayers.Add(newLayer.Name + "," + vpn.ToString());
                                        //Continuing the loop if the viewport has been erased
                                        if (vp.IsErased) {
                                                continue;
                                        //This is run if the viewport isn't a rectangle
                                        if (vp.NonRectClipOn) {
                                                //Adding the number of viewports
                                                NumberVPorts = NumberVPorts + 1;
                                                ObjectId nonrectoid = vp.NonRectClipEntityId;
                                                Polyline nrvp = tr.GetObject(nonrectoid, OpenMode.ForRead);
                                                Point3dCollection stretchPoints = new Point3dCollection();
                                                nrvp.GetStretchPoints(stretchPoints);
                                                //Adding up the number of vertices
                                                VPortVertices.Add(stretchPoints.Count + 1);
                                                Point2d firstpt = default(Point2d);
                                                for (i = 0; i <= stretchPoints.Count - 1; i++) {
                                                        Point3d newpt = new Point3d(stretchPoints(i).X, stretchPoints(i).Y, stretchPoints(i).Z);
                                                        Vector3d newvect = vp.CenterPoint.GetAsVector;
                                                        newpt = newpt.Subtract(newvect);
                                                        newpt = newpt.MultiplyBy(1.0 / vp.CustomScale);
                                                        Autodesk.AutoCAD.GraphicsSystem.View vpview = new Autodesk.AutoCAD.GraphicsSystem.View();
                                                        gsm.SetViewFromViewport(vpview, vp.Number);
                                                        Matrix3d viewmat = vpview.ViewingMatrix.Inverse();
                                                        Point3d newpt3d = newpt.TransformBy(viewmat);
                                                        Point2d newpt2d = new Point2d(newpt3d.X, newpt3d.Y);
                                                        //Adding each point into the list of coordinates
                                                        VPortCoordinates.Add(newpt2d);
                                                        if (i == 0) {
        firstpt = newpt2d;
                                                        if (i == stretchPoints.Count - 1) {
        //And adding the first point again, so we can go around in a circle
        VPortCoordinates.Add(firstpt);
                                        //This is run if it is a rectangle
                                        } else {
                                                llc = vp.Bounds.Value.MinPoint;
                                                urc = vp.Bounds.Value.MaxPoint;
                                                llc = llc.Subtract(vp.CenterPoint.GetAsVector);
                                                urc = urc.Subtract(vp.CenterPoint.GetAsVector);
                                                llc = llc.MultiplyBy(1.0 / vp.CustomScale);
                                                urc = urc.MultiplyBy(1.0 / vp.CustomScale);
                                                Point3d newllc = llc.TransformBy(viewmat);
                                                Point3d newurc = urc.TransformBy(viewmat);
                                                Point2d llc2d = new Point2d(newllc.X, newllc.Y);
                                                Point2d lrc2d = new Point2d(newurc.X, newllc.Y);
                                                Point2d urc2d = new Point2d(newurc.X, newurc.Y);
                                                Point2d ulc2d = new Point2d(newllc.X, newurc.Y);
                                                //Adding the vertices and number of viewports
                                                VPortVertices.Add(5);
                                                //Adding each coordinate in, and the first again
                                                VPortCoordinates.Add(llc2d);
                                                VPortCoordinates.Add(lrc2d);
                                                VPortCoordinates.Add(urc2d);
                                                VPortCoordinates.Add(ulc2d);
                x = x + 1;
                //Next
                endusing:
                //Dispose of the transaction
I just published a new package (‘Arkance Systems Node Library’) where you can find such functionality.
Awesome Anton! Just downloaded the package and I can’t wait to test the nodes! Will keep you posted :smiley:
@Anton_Huizinga
Hello Anton, first thank you for work with Dynamo. I can’t seem to find the input node for layers.
Thanks, Daniel.
In the library: ArkanceSystems > AutoCAD > Document > AutoCADLayer. These are real Layer objects, not just layer names as text.
That node does not appear to be present in my list.
I have v7.1 installed.
Look a little bit further in the Document folder, it has subfolders aswel, such as AnnotationScale and AutoCADColor as seen in your screenshot.
I see now. Thanks!
