Hi, help create a node with function SaveToProjectAsImage command, for saving selected view.
http://www.revitapidocs.com/2018/0bc4b117-ffd3-616f-d378-bfcbb1fdae2f.htm
Thank you.
Try something with the View.ExportAsImage node in the Revit dropdown. That should get you where you want to go.
Thank you, I tried. But it did not help me (
Can you post an image of your script?
I would do something like this:
# Copyright(c) 2018, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
clr.AddReference("RevitAPI")
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
try:
errorReport = None
options = ImageExportOptions()
options.ExportRange = ExportRange.CurrentView
options.ViewName = "Image_" + doc.ActiveView.Name
result = doc.SaveToProjectAsImage(options)
except:
# if error occurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
# Assign your output to the OUT variable
if None == errorReport:
OUT = result
OUT = errorReport
So the ImageExportOptions is where you can control image size and resolution. You can find all possibilities here: http://www.revitapidocs.com/2018/0f83e370-338f-b3a0-d5e5-b126bb31b49e.htm
Thank you very much!
