Export 3D from Background Opened Model
Hi!
I have a routine which exports 3D views from the active model and relocate the files in the correct relative path.
The main node is this:
The code:
1. import clr
2. clr.AddReference('ProtoGeometry')
3. from Autodesk.DesignScript.Geometry import *
4. # Import DocumentManager and TransactionManager
5. clr.AddReference("RevitServices")
6. import RevitServices
7. from RevitServices.Persistence import DocumentManager
8. from RevitServices.Transactions import TransactionManager
9. from System.Collections.Generic import *
10. # Import RevitAPI
11. clr.AddReference("RevitAPI")
12. import Autodesk
13. from Autodesk.Revit.DB import *
14. # Import ToDSType(bool) extension method
15. clr.AddReference("RevitNodes")
16. import Revit
17. clr.ImportExtensions(Revit.Elements)
18. import System
19. # Import geometry conversion extension methods
20. clr.ImportExtensions(Revit.GeometryConversion)
21. doc = DocumentManager.Instance.CurrentDBDocument
22. uiapp = DocumentManager.Instance.CurrentUIApplication
23. app = uiapp.Application
24. uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
25. #The inputs to this node will be stored as a list in the IN variable.
26. dataEnteringNode = IN
27. # Indicamos las vistas a Exportar.
28. views = []
29. view = IN[0]
30. # Introducimos las rutas de las carpetas donde Exportar.
31. path = UnwrapElement(IN[1])
32. # Introducimos los nombres de las vistas a Exportar.
33. names = UnwrapElement(IN[2])
34. # Fusionar vistas segmentadas
35. merge_views = IN[3]
36. # Propiedades de objeto
37. obj_prop = IN[4]
38. for j in view:
39. 	views.append(UnwrapElement(j))
40.
41. # Start Transaction
42. TransactionManager.Instance.EnsureInTransaction(doc)
43. views_set = ViewSet()
44. for z in views:
45. 	v_set = views_set.Insert(z)
46.
47. exp_opt = DWFXExportOptions()
48. exp_opt.MergedViews = merge_views
49. exp_opt.ExportObjectData = obj_prop
50. exportar = doc.Export(path,names,views_set,exp_opt)
51. # End Transaction
52. TransactionManager.Instance.TransactionTaskDone()
53. OUT = exportar
54. for v in views:
55. 	b= a.Insert(v)
56.
57. x=DWFExportOptions()
58. x.MergedViews = IN[3]
59. c=doc.Export(folder,name,a,x)
60. # End Transaction
61. TransactionManager.Instance.TransactionTaskDone()
62. OUT=c
I would like to run this routine opening models in background, so I have added IN[5], in the python node and I have edited the Python script like that in the line 21:
1. import clr
12. import Autodesk
16. import Revit
18. import System
21. doc = IN[5]
28. views = []
29. view = IN[0]
38. for j in view:
40.
44. for z in views:
46.
53. OUT = exportar
54. for v in views:
55. 	b= a.Insert(v)
56.
62. OUT=c
How could I edit the python script to make it work? Im missing something but i dont know what it is…
Thanks in advance!
Hi @GabrielCarmona,
You could use the Export DWFx in Document which already has all the inputs you need.
P.S: The transactions in your script will not work with a document open in the background.
Thank you so much @Alban_de_Chasteigner,
This node seems to fit perfectly for the routine im working on it, problem solved!
As a curiosity, if i want to edit the node I have published to work with background models, how could I do it, if the is a simple way to achive it, I think that is not too dificult but I have not hit the key :thinking:
