Hi all I am trying to rotate the linked file around its project base point but I am not able to find the center of rotation point so that I can rotate it by placing the centre of rotation at its linked project base point and rotate by some angle.
Can anyone please tell me how to rotate by placing centre of rotation at project base point by some amount of angle ?
Hi @jw.vanasselt have successfully attached revit models into the current project.
Now I want to rotate the link and move the link in z direction by some amount. So Here I was trying to use the nodes from genious loci but they are not working properly.
I want to rotate by its project point and move in z direction by some amount without changing the location of the linked model. Can you please tell me how to do that ?
I think this is a level issue. You need to use flatten between the index node and set rotation.
After that you can create a new point and set the location of you’re link instance.
Yeah it also works for me but it is getting shifted to another position. I want to rotate around its project base point only, keeping project base point of linked file as center of rotation and then I want to rotate.
