Hi guys,
I need to rotate some of the placed family instances around the project base point (my project base point and survey point are not at same location).
Is there any node that I can use to rotate the placed family instances around project base point by angle equal to value in “Angle to true north” parameter?
Well the FamilyInstance.SetRotation node only works when you need to rotate from an angle to a specified amount of degrees, so if you need to rotate a family 90 degrees from the already present rotation the FI.SR node will just set 90 degrees from (in example) the x-axis.
