How to retrieve project information parameters?
Hi All,
I’m trying to get a value from a Project parameter but I don’t quite understand how to do it. If some could give me some directions, I’ll appreciate it.
import Autodesk.DesignScript.Geometry
clr.AddReference('DSCoreNodes')
from DSCore import *
input = IN[0]
ProyInfo = UnwrapElement(doc.ProjectInformation)
ruta = ProyInfo.GetParameterValueByName("Parameter Name")
OUT = ruta
Thanks in advance!
Hi @Jorge_Villarroel
I think clockwork package has already node called “Document.ProjectParameters” it will retrieve all project parameters and the categories they are assigned to.
And also Document.ProjectInfo node.
Hi Jorge,
maybe this can help you:
clr.AddReference("RevitAPI")
OUT = []
project_info_collector = FilteredElementCollector(doc) \
                        .OfCategory(BuiltInCategory.OST_ProjectInformation) \
                        .ToElements()
for i in project_info_collector:
	project_name_param = i.LookupParameter('Project Name')
	if project_name_param:
		project_name = project_name_param.AsString()
		OUT.Add(project_name)
	project_number_param = i.LookupParameter('Project Number')
	if project_number_param:
		project_number = project_number_param.AsString()
		OUT.Add(project_number)
		OUT.Add("Perameter not found")
You should first collect the built-in category OST_ProjectInformation and then look for the certain parameter (in this case Project Name and Project Number)
Cheers, Milorad
Thanks @Milorad_Lazicic. I’ll give it a try!
You can just do
projectInfo = doc.ProjectInformation
projectName = projectInfo.Name
ProjectNumber = projectInfo.Number
i am trying to adjust the code so i get all the parameters available in project information… but i keep hitting a errror…
Clockwork has the solution to your problem :slight_smile:
This should be enough if you use pure Dynamo.
Change .Add for .append and it should work
