How do I access the System Family: Project Information object?
I would like to read parameter values that are custom parameters that are a part of the System Family: Project Information. It is not listed under Family Types and I can’t access it through GetParamiterValueByName because I can’t get the Element. Any ideas?
Hi @Vikram_Subbaiah, How do you do this in Python? I want to get one parameter value using only python but I’m still getting an error:
import Autodesk.DesignScript.Geometry
clr.AddReference('DSCoreNodes')
from DSCore import *
input = IN[0]
ProyInfo = UnwrapElement(doc.ProjectInformation)
ruta = ProyInfo.GetParameterValueByName("Parameter Name")
OUT = ruta
Thanks in advance!
