Hello there i am fairly new to dynamo.
I am trying to replace a string “m” with a string “LD”.
when i do this using the code block, other strings that are words that contain the letter “m” get replaced with LD how do i avoid this?
How do i strictly replace the string “m” only?
Diagram below
green arrow → Desired
red arrow → Not desired
String.Replace does exactly that: it replaces any instance of the searchFor term with the replaceWith term. Replacing a single character is usually not a good idea because you’ll catch every instance.
You have a few options. Because you’re dealing with only a single instance of a single character, you can just check to see if the string is equal to your term, then replace the whole string. That would avoid any substrings containing the term. Based on your example, it also looks like you’re only looking at the string at sub-index 3. If that’s the case, you can just filter out those values, replace any strings matching your term, and then put the sublist back in place.
Hello @driftblade
Maybe this will help you.
Hi, try this in a code block
I have since been careful about my phone
x.Length ==1 && x=="m"?
"LD":
x;
Sincerely
christian.stan
a solution (multi list level) with numpy, if input list is homogeny
import sys
clr.AddReference('Python.Included')
import Python.Included as pyInc
path_py3_lib = pyInc.Installer.EmbeddedPythonHome
sys.path.append(path_py3_lib + r'\Lib')
sys.path.append(path_py3_lib + r'\Lib\site-packages')
import numpy as np
data, search_value, replace_value = IN
array_3d = np.array(data).astype(object)
array_3d[array_3d == search_value] = replace_value
OUT = array_3d.tolist()
or in pure Python (input list need not be homogeneous)
import sys
def convert_value(value):
global search_value
global replace_value
return replace_value if value == search_value else value
def nestedRecursFunc(lst, functoApply):
newlst = list(lst)[:] # copy input list and convert it (if necessary)
for idx, elem in enumerate(lst):
if isinstance(elem, list) and len(elem) > 0:
newlst[idx] = nestedRecursFunc(lst[idx], functoApply)
elif isinstance(elem, list) and len(elem) == 0:
newlst[idx] = []
newlst[idx] = convert_value(lst[idx])
return newlst
OUT = nestedRecursFunc(data, convert_value)
wow, I learned another new trick with IN entrants Sincerely
christian.stan
