How to remove part of a string
Hey guys i want to remove everything that is in parenthesis in the image below. How would i do that??
hi @ZJRODGERS,
in this case in particular you could split the string by “(” and take the first part of the result.
Removing everything between parenthesis in a string is totally possible but a little more complicated.
String.Remove node is the faster solution but String.Split works also.
If you have something else after the part you want to remove, then maybe something like this:
