Hi everyone,
Can anyone tell me how to remove some characters of string?
For example, I have an item “thickness default 150mm” and I’d like to remain 150 for calculation in next steps.
Thank you in advance
Hi Hoc_Em,
What about regular expression?
There are multiple ways to do this. Regular expressions, as Einar stated, may be the most robust way, but if the data is consistent you can try something like this also:
This might work too…
Got it! Thank you for your help!
@Tomasz_Puchala’s solution seems to be the most efficient one!
Hi Guys,
I am trying to shorten file name that are coming from revit. So far I am trying to find the best way to pull apart the file name, remove a few words in the string and stitch it back together. I am not sure of the best way to do this but it seems like @Tomasz_Puchala was close with his custom python node. Right now I have successfully isolated the pieces of the file name I would like to preserve but am losing the 's because I have used them as identifiers to tell dynamo where to break up the list. Can anyone help me with this?
@kloffredo Please start a new topic and post what you have done so far.
Hi Guys,
@Tomasz_Puchala Python script works great for a list of strings. But how to make it work for a list of lists with strings? an @L3 list? or just make it work no matters the dimension of the list?
Thank you.
