Delete parts of string consecutively
Well I would like to remove different things from a string if I removed 1 by 1 it would be something simple, but if I had to remove for example 10 or 20 characters it would become a bit more complicated if
This initial script works fine but I wish it were a little faster to be able to add what you want to remove
[image]
If I transform it into a list, it does not work as I wish, it should be the same result as in the first
Hi @Christhian ,
The Clockwork Package has a node for this String.ReplaceMultiple. (Note that you need to install the IronPython2.7 package aswell in some of the latest Dynamo versions).
another possibility
Cordially
christian.stan
Python option :snake:
Thank you very much for all the answers, all three are excellent
