Hey all,
I am new to using Dynamo and I am looking for advice. What I am looking to do is, to use a fence post with a block foundation which would be a CAD block. And position it every 2 or 3m along an alignment.
I have had a go at trying to create a graph but I am not sure what you need to include.
Adam
Hi @adam.coad3178,
First, select the appropriate alignment that you want to work with. Some nodes to help with that are Select Object, Alignments, or Selection.AlignmentByName.
Next, generate coordinate systems along the alignment at whatever stations you need. The node to use for that is Alignment.CoordinateSystemByStationOffset.
Finally, create block references using the BlockReference.ByCoordinateSystem node.
Thanks for the advice. I will give this a go.
