Is there a way to locate the curtain wall system like a curtain wall?
Hi @lkh5074 ,
I don’t know what curves exactly you want to extract but the Clockwork package has a node called Element.Panels directly after your Select Model Element node, using that node you can use the OOTB node CurtainPanel.Boundaries to get all the polycurves which shape each individual panel.
The Clockwork package also has some other nodes for working with Curtain Elements btw
