I want layout multi-view block ,but it doesn’t work . How to do it ?
交通标志布置.dyn (46.7 KB)
道路标线练习底图.dwg (3.9 MB)
交通标志列表.xlsx (9.9 KB)
Hi
I had some issues with your letters so I changed into latin in the excel to make ist easier for me to test.
Also used the block reference “Single Pole Sign” and it seems to work when I changed from import csv to import excel. robably you need to continue try with the Multiview block but everything seems ok.
道路标线练习底图.dwg (2.4 MB)
excel.xlsx (9.8 KB)
交通标志布置.dyn (50.5 KB)
Next step could be to sample the elevation from corridor surface and use it as insertion elevation. Check the multiview block according to insertion point to make it insert with correct orientation.
