Hi all,
I could add LINQ in ironpython like this
clr.AddReference("System.Core")
import System
clr.ImportExtensions(System.Linq)
it doesn’t work in cpython.
I also installed the following package
pip install python-linq
but when I import it it’s not recognised . Ideas ?
Hello, I’m not the most alert on these aspects but try maybe that
import sys
import System
OUT = dir(System.Linq)
Cordially
christian.stan
The following works with ironpython
import System
from System.Linq import *
lst = [1,2,3]
LinqList = lst.Where(lambda num : num!=2).ToList()
OUT = LinqList
but not in CPython
@salvatoredragotta unfortunately LINQ do not work with PythonNet (CPython3 engine)
IronPython 2 utilizes the “Where” functionality here as it’s converting the Python list to a .net enumberable (of some sort). As CPython is ‘closer to the bare metal’ it doesn’t handle .net interop as effectively, or natively - you’ll have to build your own interop method. As a result I recommend utilizing a Python native tool for such filters. Two examples of list comprehension and filtering are as follows:
lst = [1,2,3]
lstComp = [i for i in lst if i != 2]
lstFilt = filter(lambda x: x != 2, lst)
