With Revit(2022) or Civil3D(2022), It is now possible to use 2 Python engines in Dynamo
IronPython2 (target Python 2.7)
CPython3 with Pythonnet Bridge (target Python 3.7+)
From Dynamo 2.7 onwards, you now have the option of using either IronPython2 (Which has historically been in Dynamo) or the new CPython3 - available as different engines on each Python node which compute using either Python 2 or Python 3 code respectively. Note - you can use both versions in a single graph.
From Dynamo 2.11 onwards, CPython3 will be the both the default engine and officially supported Python engine inside of Dynamo. You will be able to access IronPython2 via the Package Manager on a per-user basis.
Beyond the difference between Python 2 and Python 3, there are some differences with the .NET 4.0+ Common Language Runtime (CLR) integration:
IronPython2 → IronPython (more detail here) IronPython is a .NET native Implementation of Python for .NET Framework that is built on top of the Dynamic Language Runtime.
CPython3 → Python.NET (more detail here) Python for .NET is a package that gives Python programmers nearly seamless integration with the .NET Common Language Runtime (CLR)
What are you planning? (eventually)
I plan to migrate completely to CPython3/Pythonnet
I plan to stay on IronPython
I plan to use the 2 engines (mainly IronPython)
I plan to use the 2 engines (mainly CPython3/Pythonnet)
0voters
Note
one should not see IronPython and CPython/PythonNet as competitors, each have different qualities
In my opinion the advantages of CPython3 is enough that staying with the old is foolhardy after a point. Moving past Python 2 should eventually be a goal for everyone - locking a larger package (say Genius Loci, or Clockwork) down to 2 at the next release and starting to develop only on 3 makes sense to me.
I dont see them as competitors, i see one as a security risk because of the lack of support for Python 2 anymore. Python 2 had its EOL on 1st Jan 2020, and IronPython is developed by volunteers
Therefore we need to move onto the latest version to hopefully stay away from security risks if any end up being found.
Note: IronPython3 has been in development for a long time, still in WIP status and is done by volunteers only.
If we are only talking about Python 2 vs Python 3, the choice does not really arise (Python3).
Now if we compare the .Net integration, IronPython has some advantages over the PythonNet package, which can make the choice a little more complicated for some depending on their level of experience.
Surely everything NEW is going to be made with CPython 3.
My only concern would be the given time to us, package developers, to migrate all of our EXISTED nodes to CPython3…
For example my package consists of almost 700 custom nodes, and more than 500 dyn graphs, many which uses Ironpython 2.
We would eventually move to CPython3, but it will take years… 4 or 5 at least in my side, as I will progressively migrate/test nodes in each update, and it’s really hard work.
Will Dynamo completely switch from IronPython to CPython? AFAIK the current version of IronPython is 3.4. Will there be chance, that this will be available in future Dynamo for Revit versions?
@Karam_Baki, totally agree with you.
The power of Dynamo is speed of graphs development. So any good packages matter.
Especially great ones, like Synthesize and many more. Many authors won’t update their,
many packages are abandoned but working good!
One advantage of using CPython now in Dynamo is an ability to use native Python Packages from PyPi repo.
The IronPython 2.7 is 10 about years old now, but it works stable. If we’ll able to install Python Packages in IronPython 3.4 it will be great. Doesn’t matter, as Dynamo package or main solution.
I think we all use some antivirus software. Of course, we can say NO to all packages PyPi. But can you be shure, that all Dynamo packages are safe? Working on PC is a risk in our days anyhow.
P.S. Is CPython more safe than IronPython, if we use PyPi packages?
Do not rely on a virus scanner. They may not be able to detect a new version, but they are a ok first line of defence while not being the only thing you should do.
Some of the rogue packages that have been found out, do not install any malware but instead extract Cloud Tokens or other information which may be by-passing virus scanners.
On the note about Dynamo Packages, I generally stay with the well known packages or packages that have the source code released(eg on github).
I would treat IronPython(2.7 or 3.4) and Cpython packages as the same.
