hi everyone, I have a question. I downloaded revit 2018 but I can’t find dynamo. how can I install it? thank you very much
@jmbenavides7 Not available in the Manage tab?
no. i don’t have it. how did you get it?
If you have already installed Dynamo, You should remove it and reinstall. Go to Manage Tab and check again.
Make sure your Revit application is closed while installing and follow this steps:
Click on download
Make sure you check Revit 2018 while you install
Installing the recent update of Revit 2018.2 available from Autodesk should update/add the Dynamo installation to the tabs correctly at version 1.3.2
Available through subscription account or the Autodesk Desktop App.
thank you very much… really thank you
