How to install civil connection package and connect civil 3d with Revit … Is there a video explain that in detail … because I try to do that but I can’t get it
Check 4.2.2 and 4.3.1 of the guide here: civilconnection/Linear Structures Workflow Guide.pdf at master · Autodesk/civilconnection · GitHub
If you skip anything it will all fail to work due to the interconnected nature of the process, so best to take it slow and go line by line.
I do not know what you have tried, but i have downloaded CivilConnection2020 like this:
- Open Dynamo (2.X) from Revit, Revit version doesnt really matter.
- In Dynamo, go to “Packages” in the Ribbon and select “Search Packages”
- This will open the “Online Package Search” window, this will say in the beginning “Syncing with server…”
- When this is gone, type "CivilConnection in the search bar and use the big download button to download this.
Video: (in Dynamo)
Check the installation notes carefully. Civil Connection is driven by Dynamo for Revit and leverages Civil Python for the C3D work. Dynamo for Civil3D wasn’t around when this tool was developed.
I am with the 2021 version of both Revit and Civil. I have installed the latest version of CivilConnection and CivilPyton and I only see the CivilConnection package in Revit. Same as keith.sowinski says
That’s how it is?. The idea I had was to import Families from Revit to Civil, and not the other way around.
Thanks for the help.
Yes. CivilConnection is only for Revit. But you can import solid geometry from families into Civil 3D. You need to have Revit and Civil 3D running at the same time, then look at the nodes in the CivilDocument shelf.
Hello.
Does anyone know if the Dynamo Package “CivilConnection” does work with Revit/Civil 2022?
Or when is it planned to be available and where can I download it?
Thanks for the feedback and best regards.
Beat
