How to get this widget?
AI is not helping me well… :wink: how to run this window
clr.AddReference('DynamoCore')
from Dynamo.Graph.Nodes import *
clr.AddReference("PresentationFramework")
from System.Windows import Application, Window, Thickness
from System.Windows.Controls import ComboBox
class MainWindow(Window):
    def __init__(self):
        self.Title = "My App"
        self.Width = 200
        self.Height = 100
        self.Padding = Thickness(10)
        self.widget = ComboBox()
        self.widget.Items.Add("walls")
        self.widget.Items.Add("Floors")
        self.widget.Items.Add("Columns")
        self.widget.Items.Add("Roofs")
        self.widget.SelectionChanged += self.index_changed
        self.Content = self.widget
    def index_changed(self, sender, e):
        return (self.widget.SelectedIndex)
# Dynamo entry point
def RunScript():
    app = Application.Current
    if app is None:
        app = Application()
    window = MainWindow()
    app.Run(window)
OUT = "Script completed."
at least i have no error
grafik
KR
Andreas
You haven’t actually implemented anything. You only have definitions and the output string. Try running RunScript().
thanks, thats a starting point!
i have just bridge the gap to a collector a.s.o…
KR
Andreas
@Nick_Boyts ,
oh there is one sideaffect revit closes with closing the window!
how to avoid that?
KR
Andreas
@Nick_Boyts ,
i solved it better this way!
a = MainWindow()
a.Show()
