Just having some fun trying to get the current dispatcher thread in Sandbox to use with WPF… (eventually I would like to get it running in Revit, but that also crashes, hoping get this working will inform that)
Currently all attempts are crashing!
All thoughts welcome, I am way out of my depth
Thanks to @Michael_Kirschner2 for assistance so far.
Cheers,
Mark
# Reference the WPF assemblies
import sys
import System.Windows
from wpf import *
from System.Threading import Thread, ThreadStart, ApartmentState
clr.AddReference('PresentationFramework')
# Initialization Constants
Window = System.Windows.Window
Application = System.Windows.Application
app = Application()
appD = Application.Current.Dispatcher
#Dispatcher = System.Windows.Threading.Dispatcher.CurrentDispatcher;
def appThread():
# Create window
my_window = Window()
# Run application
my_app = appD
my_app.Run (my_window)
thread = Thread(ThreadStart(appThread))
#thread.SetApartmentState(ApartmentState.STA)
thread.Start()
thread.Join()
So thanks to Michael, I have got this running in Sandbox…
import sys
from wpf import *
def appThread():
my_window.Show()
thread = Application.Current.Dispatcher.Invoke(appThread)
However in DynamoRevit, it is still chucking an error (presumably due to Revit having 1 thread not a separate dispatch thread.
I found an interesting thing here… https://pythoncvc.net/?p=247 and doctored it to get it running in Dynamo Revit
import sys
from wpf import *
clr.AddReference('RevitAPI')
# noinspection PyUnresolvedReferences
from Autodesk.Revit.UI import IExternalEventHandler, ExternalEvent
from Autodesk.Revit.DB import Transaction
from Autodesk.Revit.Exceptions import InvalidOperationException
from RevitServices import *
from Autodesk.Revit.UI.Selection import *
# Simple function we want to run
def delete_elements():
t = Transaction(doc, "Failing script")
t.Start()
for elid in uidoc.Selection.GetElementIds():
print elid
doc.Delete(elid)
t.Commit()
# Create a subclass of IExternalEventHandler
class SimpleEventHandler(IExternalEventHandler):
Simple IExternalEventHandler sample
# __init__ is used to make function from outside of the class to be executed by the handler. \
# Instructions could be simply written under Execute method only
def __init__(self, do_this):
self.do_this = do_this
# Execute method run in Revit API environment.
def Execute(self, uiapp):
try:
self.do_this()
except InvalidOperationException:
# If you don't catch this exeption Revit may crash.
print "InvalidOperationException catched"
def GetName(self):
return "simple function executed by an IExternalEventHandler in a Form"
# Now we need to make an instance of this handler. Moreover, it shows that the same class could be used to for
# different functions using different handler class instances
simple_event_handler = SimpleEventHandler(delete_elements)
# We now need to create the ExternalEvent
ext_event = ExternalEvent.Create(simple_event_handler)
# A simple WPF form used to call the ExternalEvent
class ModelessForm(Window):#WPFWindow):
Simple modeless form sample#
def __init__(self):
Window.__init__(self)
self.Title = "Hello World"
self.Show()
def delete_click(self, sender, e):
# This Raise() method launch a signal to Revit to tell him you want to do something in the API context
ext_event.Raise()
# Let's launch our beautiful and useful form !
modeless_form = ModelessForm()
