How to get the red outline from the H column. I tried one way is to get the BoudingBox from the element, but when the column is rotated, the result is not as expected
Hi @vanquyet9494 ,
Perhaps a convex hull might work here, if you don’t know what that is please read into it :slight_smile:
Thanks @Daan this is probably the key word, I’ll look into it
Hi @vanquyet9494 ,
I found a solution which seems a lot easier than creating Convex Hulls:
PS: The Element.GetRotation node is from the Genius Loci package
Thank you so much!
