I’m trying to get a list of the Workset names that the links resides in from the model. so i wonder if there is a node in dynamo that can pull the name of the workset
clr.AddReference('RevitAPI')
clr.AddReference('System')
#🌈 links
linked_docs = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType().ToElements()
lnkInstance = [i for i in linked_docs if i.Name.Contains("ARCH")]
doclnk = lnkInstance[0]
# 🎹 get workset
worksetId = doclnk.WorksetId.IntegerValue
OUT = worksetId
It’s just a parameter and an element/Id. You should be able to get the value with GetParameterValueByName. There’s a weird bug in some versions where workset sometimes returns the element and sometimes returns the Id, but you can deal with either. You can get the element from the Id if you need to and then get the name directly from the element.
With a little python (or the right custom node), you can also get it directly via the parameter with AsValueString().
Both works thanks guys ![]()
