Here they explain well how to convert internal units to meter, centimeters,…
actually when i don`t know the current units in my project, how can i call them? and use it as a variable f.e. whats the current length in the document, and convert it ?
KR
Andreas
In Crumple i have a node for this in Python, should be called getunittypes I think.
"Uuid": "188c3e69-da99-4eba-a859-d030d4b45a9f",
"IsCustomNode": true,
"Category": "Crumple.Application.Query",
"Description": "Returns the unit type or forgetypeId of the document's units.",
"Name": "© Revit.GetUnitTypes",
"ElementResolver": {
"ResolutionMap": {}
"Inputs": [],
"Outputs": [],
"Nodes": [
"ConcreteType": "PythonNodeModels.PythonNode, PythonNodeModels",
"NodeType": "PythonScriptNode",
"Code": "# Made by Gavin Crump\r\n# Free for use\r\n# BIM Guru, www.bimguru.com.au\r\n\r\n# Boilerplate text\r\nimport clr\r\n\r\nclr.AddReference(\"RevitServices\")\r\nimport RevitServices\r\nfrom RevitServices.Persistence import DocumentManager \r\n\r\n# Current doc/app/ui\r\ndoc = IN[0]\r\n\r\n# Get app version\r\nuiapp = DocumentManager.Instance.CurrentUIApplication \r\napp = uiapp.Application\r\nrvt_year = int(app.VersionNumber)\r\n\r\n# Import API references by version\r\nclr.AddReference(\"RevitAPI\")\r\nimport Autodesk \r\n\r\nif rvt_year < 2022:\r\n\tfrom Autodesk.Revit.DB import UnitType\r\nelse:\r\n\tfrom Autodesk.Revit.DB import SpecTypeId\r\n\r\n# Get units\r\nif rvt_year < 2022:\r\n\tintLenUnits = doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits\r\n\tintAreaUnits = doc.GetUnits().GetFormatOptions(UnitType.UT_Area).DisplayUnits\r\n\tintVolUnits = doc.GetUnits().GetFormatOptions(UnitType.UT_Volume).DisplayUnits\r\nelse:\r\n\tintLenUnits = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()\r\n\tintAreaUnits = doc.GetUnits().GetFormatOptions(SpecTypeId.Area).GetUnitTypeId()\r\n\tintVolUnits = doc.GetUnits().GetFormatOptions(SpecTypeId.Volume).GetUnitTypeId()\r\n\r\n# Preparing output to Dynamo\r\nOUT = intLenUnits, intAreaUnits, intVolUnits",
"Engine": "IronPython2",
"VariableInputPorts": true,
"Id": "e2836d27dcd447bda3a62ec066f6e9e0",
"Inputs": [
This file has been truncated. show original
