Hi all,
I have three wall at 45° but i can’t understand how to group wall at 45°. it’s make it 2 group of wall as per below snip.
Hi all,
Hi @robert12546358 ,
Could you share a screenshot of your Dynamo script after implementing the suggestion of @sovitek ?
What is the problem? You only have one group, together with one corresponding key.
Alright…why do you use list level 2…dont think i understand the problem and what you try then
I see, this is not grouping by angle though.
If you want to group them by their continuous line you could approach this “mathematical”.
First start by grouping them by their rotation value. Then group them by their intersection point with the Y-axis, you can do this by creating a plane in Dynamo along the X-axis, then project the wall’s vector/ line onto that Plane, such that you find the intersection of the plane and the wall line (if it was extended).
Then simply only get the Y-value of that intersection point and then group your walls again by that.
PS: This is how I would do this, maybe there are other, better ways.
I think it’d be best to try the following here.
). This is now a single item which can be used as a key in the context of the larger design.Give it a shot and if you get stuck I’ll take a stab at it later this week.
good evening,
there may be the possibility of using Thales and similar triangles with an inclined line large created from one of the low points,
I will try to dig on this side after tomorrow
Cordially
christian.stan
Took a stab at my method; Pretty good results as it will group 2000 curves by alignment in about 4.5 seconds. Your mileage may vary of course.
The DesignScript definition I used is as follows:
def groupAligned (crvList: Curve[])
bb = BoundingBox.ByGeometry(crvList);
dist = Geometry.DistanceTo(bb.MinPoint,bb.MaxPoint);
extended = crvList.ExtendStart(dist).ExtendEnd(dist);
boundRec =
PolyCurve.ByJoinedCurves(
bb.ToCuboid().Explode().PerimeterCurves()
)[0];
intersects =
DSCore.List.Transpose(
DSCore.List.Sort(
Curve.ParameterAtPoint(
boundRec,
Geometry.Intersect(boundRec,extended)
)@L2<1>
uvVals = UV.ByCoordinates(intersects[0],intersects[1]);
groups = DSCore.List.GroupByKey(crvList,uvVals);
return = groups["groups"];
hello, another possibility
create bounding boxes around elements
create lines joining the centroids of the 1st with respect to the other centroids if all these lines are tilted by 45°,
it means that these objects are aligned (remove them from the list then, start again with the non-removed objects until the end of the list)
unfortunately I am not competent enough to format it ,
after I am not sure of the greediness in calculation time
Cordially
christian.stan
I tried another possibility (Intersection of the midplanes of the walls) , I’m on the right track but I don’t know the node (List.GroupBykey to have a correct end)
occasionally if you could enlighten me (depending on your schedule), that would be nice of you. Thanks in advance.
essai verif colinearite.dyn (31.8 KB)
A curious thing (the intersection of 2 planes returns Pi (hidden)
cordially
christian.stan
Can you quickly outline the logic in steps as I did above?
I’ll look into this later this week if so.
Thanks,
To follow up on the message
1-Selection of walls with the same inclination
2-Recovery of the support lines of the walls
3-Creation of vertical planes passing through the median axis of the walls
4- Intersection of these same planes between them (vector product) with the same entrants
5-Consequence:
Surface exists (collinear), empty (not collinear)
6- I empty-handed to clip at the end (I’m a beginner)
I did a test with 7 walls as a screen
Cordially
christian.stan
An alternative using vectors comparison (cross product)
import sys
#import Revit API
clr.AddReference('RevitAPI')
def group_byAlignement(lstelems, i = 0):
recursive function to group linear walls using vector comparison
if len(lstelems) > 0 and i < 2000:
group = [lstelems.pop(0)]
baseVector = group[0].Location.Curve.Direction
basePt = group[0].Location.Curve.GetEndPoint(0)
idxToPop = []
for idx, elem in enumerate(lstelems):
vectB = elem.Location.Curve.Direction
ptB = elem.Location.Curve.GetEndPoint(0)
vect_between_walls = DB.Line.CreateBound(basePt, ptB).Direction
if round(baseVector.CrossProduct(vectB).GetLength(), 3) == round(vectB.CrossProduct(vect_between_walls).GetLength(), 3) == 0.0:
group.append(elem)
idxToPop.append(idx)
other = [e for idxa, e in enumerate(lstelems) if idxa not in idxToPop]
return [group] + group_byAlignement(other, i + 1)
else: return []
toList = lambda x : list(x) if hasattr(x, '__iter__') else [x]
lstelems = toList(UnwrapElement(IN[0]))
OUT = group_byAlignement(lstelems)
