I try to get the door hand orientation from linked document, however using the node from archilab returned not accurate result. I would like to place new door in current document with the same hand and facing direction. Below is the graph that could describe this problem
As you can see, both doors is correctly orientated (highlighted DoorA is the door in current document), however the hand vector is not the same. “Door Set Handling” node also returned inaccurate result. My best guess is that they utilized the flip control state of the doors to determine the orientation, and since the door from linked that were flipped not necessary means it’s equal to the flipped state door in current document, thus the inaccurate result.
Is there a precise way to get the vector in this case? So that I could compare both vectors in current document with linked document, if they are different, I shall flip the hand and vice-versa.
Thanks in advance!
