How to get distance between point and line and get z value ( z axis)
Hi!
I have a line x and 2 point a,b. How to get distance of point to line and get (+) or (-) of value.
I tried use node Geometry.Distance but get only value.
In image, line x is above point a: distance = +205
line x is under point b: distance = -617
Thank Advance!!!
hello, you make the difference of your projected points in Z (pt.proja-pt.a)
Cordially
christian.stan
Hi christian
Thank you!!!
But this is case not good
I dont know why distance very big
here is an example
Cordially
christian.stan
Hi @manhgt214
You can use Vector.ByTwoPoints and compare their direction.
Also you can get coordinate values from vectors, so if the distance is an Height value, for example, you can use the Vector.Z node to get its value. Depending on it direction you’ll get a positive ou negative value.
Hi
try this script
you need to use “BriMohareb_23” Pakege
distance between point and line.dyn (43.7 KB)
Thank you!!
But I think can solved with solution of Mr.Christian.
