hello I am trying to get a point X and point Y from the line, but eventually, I am getting an error
If you want to get the distance between two lines, you can use the node Geometry.DistanceTo
which will return the minimum distance between them.
To get particular coordinates from a point on a line, you need to get the point first. Options:
Curve.StartPoint
Curve.EndPoint
Curve.PointAtParameter
thank you
