How to get an item with a specific value from a list
I want to get all items in the list with z=3000. Is there a way of doing this?
Thank you in advance.
@benameram
You can use the String.Contains node followed by a filtering by boolean.
Hi @stefan.pandaciuc
Thank you for getting back to me. I have tried your suggestion but I am getting an error as seen below. it looks like the node doesn’t like the input.
Try to place String.FromObject before String.Contains
It may work
Thank you so much for your help. the code worked but when I insert it into the next node I get this error. it looks like it doesn’t like the input as a string, even though it’s not. I got the same items of z=3000 with a manual method and it works.
Into the filter by bool mask, at the list, connect with the node that goes in string.fromobject.
This way you filter in/out the actual list, based on the string.
Thank you @stefan.pandaciuc. It worked.
You can also try with List.AllIndicesOf to get all the indices of 3000, then GetItemAtIndex to get them
