How to geht the filepath from linked dwgs?
i see all with the Lookup table, but where is the path of my .dwg ?
grafik
dwg = UnwrapElement(IN[0])
nam = [i.Path() for i in dwg]
OUT = nam
KR
Andreas
Use the .GetExternalFileReference() method
Might want to add a conditional check against it’s property .IsLinked also as I’m pretty sure imports wont have a reference. But maybe they do? Try it out without first.
@haganjake2 ,
i found this but i stuck in the syntex
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
collector = FilteredElementCollector(doc).OfClass(typeof(CADLinkType))
file_paths = []
for el in collector:
	try:
		CADLinkType link = doc.GetElement(el.Id) as CADLinkType
		isLinkedFile = link.IsExternalFileReference()
		if isLinkedFile == true:
			ExternalFileReference exFiRef = link.GetExternalFileReference()
			ModelPath path = exFiRef.GetPath()
				#pathString
			if path.ServerPath == true:
				pathString = path.CentralServerPath
				file_paths.append(pathString)
				pathString = path.ToString()
	except:
		file_paths.append("Does not work")
OUT = file_paths
i got this @haganjake2
the dwgs are linked!
grafik
… set from C# to python :confused: Solved: Re: Get filepath of linked CAD file (non-rvt file) - Autodesk Community
That’s because the method is for ImportInstances (which is what you showed in your first screenshot).
But now you are using cadlinktype’s.
Try the same method on the import instance, maybe just try it with 1 first also?
@haganjake2
i get still an error, but i am not sure if i use .IsLinked correct
grafik
KR
Andreas
You need to put line 38 inside the if condition checking if it is a link or not.
The error you are getting is because it is trying to get the reference from an import not link (I think)
Let do simple than, I saw your code so many issue syntax basic, I hope it don’t relate to chat GPT :slight_smile:
paths = []
def GetExtFileRefPath(item):
	try :
	   dirRefs = item.GetExternalResourceReferences()
	   for i,v in enumerate(dirRefs):
	       paths.append(v.Value.InSessionPath)
	   return paths
	except Exception as e: return e.ToString()
items = FilteredElementCollector(doc).OfClass(CADLinkType).ToElements()
OUT = [GetExtFileRefPath(x) for x in items]
