How to find the floor part sizes
Is there any way to get the schedule of the floor parts sizes (Width & Length).
If can’t schedule the size any other options available to do the floor tile.
Are these tiles represented by a hatch pattern?
You can’t schedule a hatch, but you can use the hatch lines to derive the data you’re after. Depends on the intended use and incoming data state.
This not a Hatch, Its a Parts element created on floor.
Generally we can extract length & Depth for wall hosted parts.
In that way we have any options to extract floor hosted parts?
So you converted the floor to parts?
Next step is to select the floor (not the parts), extract the parts therefrom, filter the parts to the material in question, get the geometry from that, and extract the minimum bounding volume for each, write the length, width and depth to parameters of each part, and then you can schedule with filter by material if memory serves.
Thanks for your guidance.
I got the schedule using the attached script.
DY-Q002 - Schedule for Parts ( Floor Host ).dyn (42.1 KB)
If you can simplify the script let me know,
Thanks.
You converted your floor to parts to show tiles?
I could be wrong here @jacob.small will correct me if I am :smiley: …
but surely there’s a better way to do that? Revit parts can make the model quite chunky.
Parts actually aren’t that bad for this - in fact I’ve done similar a few times (in fact it was floor tiles). The difficulty comes in the volume of data mostly, and if you’re adding 10000 family instances for tiles or 10000 parts it’s the same impact. Since the parts are basically split by sketch they felt only slightly more impactful than any other sketch element. The hard part came in managing the VG and associations.
Maybe I am just overcomplicating things, but.. if performance is key, you could filter out the parts by area, and erase those that are equal to the “complete” piece. Then, you have parts just for the “cut” pieces. Counting complete pieces is a non-issue. I suppose the benefits add up with bigger spaces. And applying a matching hatch to the topmost floor material would guarantee visual fidelity on views were the parts are not visible, while retaining all the are, numbers etc data for scheduling.
I was on the stone-for-architectural finished business for almost 10 years, and in my particular case, so my opinions might be biased towards my experiences.
